rate limit
Nov 13th, 2009
Hi...is it possible to segment the bandwidth for a particular host so that a particular host should get the more bandwidth than others
Joseph W. Doherty Fri, 11/13/2009 - 04:42
Much depends on features of the network device(s) that the host is connected to. Also depends on whether you want to regulate bandwidth to and/or from the host and where you wish to provide such regulation.
ror.sanjeev Fri, 11/13/2009 - 06:18
hi...thanks for the reply.
the subnet to which host belongs, connected to a 7507 router and host at other end belongs to other subnet which is connected to 2811 Cisco router's interface.There is 2Mbps point-to-point connection between two routers.I would like to segment the 2Mbps bandwidth so that particular host in both subnets should get the more bandwidth than others.Say the following topology:
Subnet:,host,gateway(router) <<-----2Mbps Connection--->>Subnet,host,gateway(router):, there are also other hosts in both subnets.I want to segment the bandwidth so that host and should get at least 128Kbps bandwidth , and others will get the remaining bandwidth..Is it possible to do , if yest then on which network device, either on router at both ends or hosts ate both end ???
Network and Security Admin
Joseph W. Doherty Fri, 11/13/2009 - 09:30
Giuseppe provides the answer in your other (similar) posting in "LAN, Switching and Routing: Traffic engineering".
