adding 3750 to stack
Answered Question
Nov 13th, 2009
I just moved a 3750 switch from a stack where it was #4. I wiped out the config by holding in the mode button, then checked it through the console port.
Then I installed it in another stack as the #3 switch, removing the stack cables while the other 2 switches were powered up and connecting them to the unpowered switch #3.
I then powered up the #3 switch. Everthing seemed to work fine except that the switch shows up as #4 instead of three. Did I miss something here?
Correct Answer by vvasisth about 7 years 5 months ago
If you manually change the stack member number by using the switch current-stack-member-number renumber new-stack-member-number global configuration command, the new number goes into effect after that stack member resets (or after you use the reload slot stack-member-numberprivileged EXEC command) and only if that number is not already assigned to any other members in the stack.
Here is the link for the bible of 3750 STACk :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_20_se/configuration/guide/swstack.html
Varun
Correct Answer by Collin Clark about 7 years 6 months ago
You can renumber the switch. See the Add a Provisioned Switch to a Switch Stack paragraph. The link should answer your other questions as well. For even more detailed info, check the configuration guide for the 3750s.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#Add
Overall Rating: 5 (4 ratings)
Correct Answer
Collin Clark Fri, 11/13/2009 - 06:27
  • Purple, 4500 points or more
Correct Answer
vvasisth Tue, 12/08/2009 - 03:32
  • Silver, 250 points or more
Varun
