Cisco SA520 VPN Connections
Nov 13th, 2009
Do they require additional licensing, or are they included with the device? Does it make a difference whether Hardware VPN to another Device or Software VPN to remote user?
Steven Smith Fri, 11/13/2009 - 06:36
I know the SSL VPN's are licensed.  I don't believe the other VPN connections are.
jabrimfi Fri, 11/13/2009 - 06:39
Thanks for the follow up Steven.   Can you go into more detail regarding this?  Is there a white paper or data sheet that a partner can look at to come up with the correct solution?
Related Content
