WLC MR code
Nov 13th, 2009
I am planning to upgrade to this code and i wanted to know if anyone have experience any issues .
Thank you
Scott Fella Fri, 11/13/2009 - 07:22
That is pretty new as it only came out this week. Again, we had to upgrade to this code on a 5508 due to the was not uploading a 3rd party certificate correctly. However, this was not an issue with the 440X or WiSM's.
I alway say to wait and see, unless you have issues with the code you are running. No reason to upgrade unless something is broken and even then, the new code might not even fix the issue or might even introduce new ones.
Just my thought.
I installed 6.0.188 on a pair of WiSM controllers and have 100+ APs running on it now. I upgraded from 4.2.207 and the upgrade went without any problem. The primary reason I moved quickly on this code is because it is supposed to address the problem with old Vocera badges connecting to 1252 access points. I will be upgrading 500+ APs on several other WiSMs in the next couple of weeks.
Darren Ramsey Fri, 11/13/2009 - 11:10
The B1000 badges are much better on with the new CLI command "config 802.11b faster-carrier-tracking-loop enable". Badge to AP association seems to be faster and voice recognition appears to be more reliable on 1142/1252. Currently running at 3 sites and will complete our migration at our two main Vocera sites next Thursday night.
George Stefanick Sat, 11/14/2009 - 06:06
Im bringing 4 WiSMs and 300 aps online next week and i appreciate the feedback.
I will report back if i see anything ..
George Stefanick Sun, 11/15/2009 - 08:54
what is going on with these caveats. Im concerned about the voice. Also the code is ED not MR?
Table 3 Major Open Caveats
ID Number
Caveat Title
AP 1140 not joinning WLC and logging tracebacks.
AP 1240 beacons getting disabled while probes enabled on WLC 6.0.182
AP1142 reset from watchdog timer expired
AP radio UP transmitting only beacons
WLC locks up on SNMP task when pushing AP Group template from WCS
Beacon stopped after much Voice traffic wre placed under a LAP.
Leo Laohoo Mon, 11/16/2009 - 13:33
With this new version did they fix the OTAP vulnerabilities yet?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
