RME 4.2 NetConfig deploys truncated MOTD
Nov 13th, 2009
  • Gold, 750 points or more
Using the out-of-the-box Banner template, RME 4.2 NetConfig reported deployment was successful on a CatOS 8 switch during both test runs. However, post baseline shows the MOTD is truncated and thousands of blank lines were inserted.
Is there any known issue or caveat with this template or NetConfig? I've attached both NetConfig job directories and pre/post switch config baslines to TAC case 612974651.
Joe Clarke Fri, 11/13/2009 - 10:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There are no known issues with NetConfig on CatOS which would explain this. However, I'm not sure how many people were using this template on CatOS, though. You may very well have found a new bug.
