francisco_1 Fri, 11/13/2009 - 08:43
  • Gold, 750 points or more
see this http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&topicID=.ee6e1fa&fromOutline=&CommCmd=MB?cmd=display_location&location=.2cd4c89c
few people have raised same question!
You can have redundant or backup link or if you have multiple context you can have active/active depending on how you setup your context or have a router infront of the ASA doing PBR..
mkharban Fri, 11/13/2009 - 10:33
Please look at the following:
Terminating two ISPs on ASA/PIX-
ISP1------------------Internet
1.1.1.2 |
1.1.1.1 |
PIX/ASA|2.2.2.1----2.2.2.2|ISP2
3.3.3.1
Internal Network
Lets say we has above setup, with ISP1 being the Primary ISP
and ISP2 being the Secondary ISP.
I'm assuming that you all know how ISP failback is configured and
how it functions. To summarize, in ISP failback all traffic goes out
using ISP1 and if it fails, ASA/PIX starts routing traffic via ISP2.
Scenario I
Now, we do not want to configure ISP failback, but we needs
to route Web (port 80,443) traffic via ISP2 and all other traffic
via ISP1. This requires PBR, which is not supported on ASA/PIX, but
we can configure a workaround on ASA/PIX to make it work.
Following are the commands which will achieve it-
route ISP1 0 0 1.1.1.2 //Default route pointing to ISP1
route ISP2 0 0 2.2.2.2 2 //Default route with Metric 2 via ISP2
static (ISP2,inside) tcp 0.0.0.0 80 0.0.0.0 80
static (ISP2,inside) tcp 0.0.0.0 443 0.0.0.0 443
sysopt noproxyarp inside
nat (inside) 1 0 0
global (ISP1) 1 interface
global (ISP2) 1 interface
Thats it !! Now all the traffic destined to any address on port 80/443
will be forcibly put on ISP2 interface and routed from there.
Note: This stuff requires that we KNOW what the destination ports are,
if there is some traffic which uses dynamic ports, like voice traffic
we will have to route it via ISP1 and cannot make it route via ISP2.
Scenario II
In the same setup, if we say that we wants half traffic to go
via ISP1 and half traffic via ISP2, first we need to understand
that ASA is NOT a load-balancer or packet-shaper. Hence we cannot
*truly* achieve this, but we may configure ASA in such a manner that
traffic for some destination IP address is routed via ISP1 and some
is routed via ISP2. Following would be configuration commands in this
scenario-
nat (inside) 1 0 0
route ISP1 128.0.0.0 128.0.0.0 1.1.1.2
route ISP2 0.0.0.0 128.0.0.0 2.2.2.2
The first creates a default route that routes addresses with the first
bit of 1 to 1.1.1.2 of ISP1.
The second creates a default route that routes addresses with the first
bit of 0 to 2.2.2.2 of ISP2.
Note: This will do traffic routing based on *Destination* IP addresses and
NOT based on traffic load. As I mentioned, ASA is NOT a packet-shaper.
Hope this helps!
Manish
Cisco TAC
