WVC210 with Safari - why no audio
Nov 13th, 2009
Running WVC210 with firmware 1.1 operates as expected with IE. I know documents state limitations with Safari/firefox with regards to motion detection. However audio via simplex-listen is not available (nor speaker icon) for Safari (4.0.4). Is this also a limitation or is there a possible work-around?
f0rmless0ne Sat, 02/13/2010 - 00:37
You probably already have your answer, but the only reason why audio works is because of the Active X control that is loaded... and active x is not supported under firefox or safari, just IE.
