How can remove APs looking for
Nov 13th, 2009
Hello all
I have a large LWAPP and CAPWAP based access points. They are all manged by WLCs.
1. I have noticed that all the APs on reboot, seek to associate to I really need to prevent/remove this feature. How can I do it using WLC or WCS?
2. Also, I have to remove the default user name and password from the access points using WLC or WCS. How can I do it.
Thanks a lot in advance.
Peter Nugent Fri, 11/13/2009 - 13:02
To change Username PW
on the wlc cli
Config ap username xxx pasword yyy all
Not sure on the other my thought was after it has joined a CAPWAP controller it shouldnt look for LWAPP on restart but not tested it someone here will be able to help
bghobadi2 Fri, 11/13/2009 - 13:07
Thanks a lot for the AP user name and password. I will keep searching a solution for the domain DNS record issue.
