State interface in the ARP Table
Nov 13th, 2009
I keep receiving the following msg every 10min.
"Deny inbound UDP from to on interface inside"
I have discovered the ip is located in my ARP Table with the interface set to STATE.Please help.
mkharban Fri, 11/13/2009 - 10:00
You are getting this message because there is no natting done for It looks like the STATE interface has a higher security level than the interface from which is coming.
Hope this helps!
Cisco TAC
