VPN connection between Cisco 2811 & PIx515e
Nov 13th, 2009
I would like to configure a VPN connection to Cisco 2811 Security IOS to a PIX 515e in a lab enviroment. I would lie to use a crossoer cable between the interfaces. i do have 2 extra router and 2 switch if there needed. I'm trying to get a bette understanding of the VPN security.
reginaldjohnson Fri, 11/13/2009 - 12:15
Do suggest using a crossover cable or using a router as the cloud between the pix & router?
Jon Marshall Fri, 11/13/2009 - 12:18
Reginald
Personally i would use at least one of the spare routers to represent the cloud. This will actually simulate a more real world environment that just using a crossover cable and there will always be routing involved in this type of scenario in the real world.
Jon
