configureing PPPOE on cisco 1841 router
Nov 13th, 2009
hi friends,
i am having broadband connection from my ISP .. it is RJ45 connection i need to configure this connection in 1841 router..
but the ISP given me username and password to get internet by dailing..
how i will configure using ethernt interface in cisco 1841 router.
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Sat, 11/14/2009 - 01:55
  • Hall of Fame,
    Founding Member
Hello Cyril,
see this example
https://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_example09186a0080094475.shtml
you don't need the vpdn part if your IOS is recent.
username and password has to be added to dialer interface configuration with commands like
int dialer 1
ppp authentication chap pap
you can configure username and password using
username xxx password yyy
in global config mode
Hope to help
Giuseppe
zeuscyril Sat, 11/14/2009 - 21:42
hi
i am using 1841 router and my interface cable is RJ45 cable not ADSL cable RJ11.
so i need to connect any one of the fast ethernet port in 1841 then how i can use dialer interface..
it is possible
Giuseppe Larosa Sat, 11/14/2009 - 23:48
  • Hall of Fame,
    Founding Member
Hello Cyril,
it is possible sorry for my misunderstanding
interface FastEthernet0/0
no ip address
speed auto
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
this links to dialer interface
interface Dialer0
ip address negotiated
ip access-group 105 in
ip mtu 1454
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1414
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp authentication pap callin
ppp chap hostname johnroche
ppp chap password pppoeisgreat
ppp chap refuse
ip route 0.0.0.0 0.0.0.0 Dialer0
on internal interface
int f0/1
ip address 192.168.11.250 255.255.255.0
ip nat inside
speed 100
full-duplex
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 192.168.11.0 0.0.0.255 any
Hope to help
Giuseppe
