Laurent Aubert Sat, 11/14/2009 - 19:03
I'm not sure if it's expected or not but here are some tips to check everything is working fine:
First you need to be sure your peer is EIGRP NSF aware:
Router# show ip protocols
EIGRP NSF-aware route hold timer is 240s
EIGRP NSF enabled
NSF signal timer is 20s
NSF converge timer is 120s
"EIGRP NSF enabled" is only for the router which has redundant SUP.
Then you should see this message on the peer facing the restarting router:
*Oct 4 11:39:18.092:%DUAL-5-NBRCHANGE:IP-EIGRP(0) 2:Neighbor
135.100.10.1 (POS3/0) is up:peer NSF restarted
Also a debug eigrp nsf and debug ip eigrp notification are available to follow the process.
Laurent.
