Upgraded ASA 5520 from 8.0.3 to 8.0.4.48 and memory up quite a bit
Nov 14th, 2009
I have upgraded our 2 ASA firewalls (Active/Standby) from 8.0.3 to 8.0.4.48 and the memory has gone from 280mb to 450mb, the ASA's have 512mb.
Is this normal/ok?
I will call Cisco TAC on Monday, but seems quite a jump to me, I'm wondering if it has turned something on I don't need, not sure how I can check.
plumbis Sat, 11/14/2009 - 10:24
  • Silver, 250 points or more
This is expected due to new features. I would suggest disabling threat-detection to free up some memory. As long as you aren't seeing a steady increase in memory I wouldn't sweat it.
plumbis Sun, 11/15/2009 - 08:26
to see what threat-detection features are enabled issue the command "show run threat-detection"
to disable those features use the "no" keyword before them.
For example
ciscoasa# sh run threat-detection
threat-detection basic-threat
threat-detection statistics access-list
ciscoasa# conf t
ciscoasa(config)# no threat-detection basic-threat
ciscoasa(config)# no threat-detection statistics access-list
whiteford Sun, 11/15/2009 - 12:15
I tried that but made no difference to the amount of memory being used, how can I show what is taking it all up?
Jerry Ye Sun, 11/15/2009 - 15:22
  • Cisco Employee,
You can try show proc mem.
HTH,
jerry
plumbis Mon, 11/16/2009 - 19:13
The top two offenders are tmatch compile and dispatch unit. tmatch compile is related to ACLs and dispatch unit related to traffic.
How big are your access lists? (show access-list | i elements)
What is the platform?
How much traffic is going through this box?
Are there drops, errors, overruns or underruns on the interfaces?
