11-14-2009 10:24 PM - edited 07-03-2021 06:15 PM
hi folks:
Has anyone of you tried to convert autonomous to lwapp mode? I used upgrade tool v3.4 and it said 1140 is not supported. Or is there any other way to do the conversion? Thanks.
regards
Alex
Solved! Go to Solution.
11-15-2009 10:09 AM
Was it a LAP to begin with? If so, follow the "LWAPP revert to autonomous" steps using the recovery image as your file. Yes - I know you are going to LAP, not to autonomous. These steps worked great for me when going from autonomous back to LAP (without using the conversion tool):
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Set the timeout value on the TFTP server to 30 seconds.
Step 4 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View; then uncheck the Hide extensions for known file types check box.
Step 5 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 6 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 7 Disconnect power from the access point.
Step 8 Press and hold MODE while you reconnect power to the access point.
Step 9 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 10 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 11 After the access point reboots, reconfigure it using the GUI or the CLI.
11-15-2009 10:09 AM
11-15-2009 06:14 PM
Hi Alex,
If you prefer to use CLI then try the following steps:
Autonomous to LWAPP (Shortcut)
Requirements:
⢠Image file (The recovery file has the prefix ârcvâ in the image name, such as c1200-rcvk9w7-tar.122-15.JA.tar);
⢠AP is connected to the Wireless LAN Controller; and
⢠AP can ping the TFTP server where the image is located.
Procedure
1. Copy the recovery file to the AP using the following command:
archive tar /x tftp://
2. Let the AP boot on this image:
boot system flash:/
3. Reboot the AP.
OPTIONAL
⢠DO NOT ALLOW THE AP TO JOIN THE WIRELESS LAN CONTROLLER IN ORDER TO USE THE OPTIONAL COMMANDS BELOW.
⢠IF POSSIBLE, type the following commands:
ï¾ clear lwapp private-config (This will bring the AP to factory default.);
ï¾ clear lwapp ap ip address
ï¾ clear lwapp ap hostname
ï¾ clear lwapp ap controller ip address
4. Let the AP connect to the Wireless LAN controller.
OPTIONAL
If an AP refuses to join the Wireless LAN Controller, type the following command from the AP:
