ASA 5505 Issue
Answered Question
Nov 15th, 2009
I have an ASA 5505 and setup a outside interface that has ip address dhcp for my internet connection. I am running dhcp on this box for my inside network. I ping the ip addresses on the internet however I keep getting these errors when I try to browse the internet from the inside network.
6 Nov 15 2009 14:15:38 110002 192.168.1.10 2069 Failed to locate egress interface for TCP from inside:192.168.1.10/2069 to 77.178.232.99/80
6 Nov 15 2009 14:25:56 305012 192.168.1.10 58055 86.16.2.106 1038 Teardown dynamic UDP translation from inside:192.168.1.10/58055 to outside:88.16.2.106/1038 duration 0:00:30
Correct Answer by Jon Marshall about 7 years 5 months ago
Charlie
So the outside interface is up and getting an IP address ?
If so can you check your routing table - you should have a default-route in their pointing to the next-hop ISP address.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Sun, 11/15/2009 - 12:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Charlie
Jon
Charlie Mayes Sun, 11/15/2009 - 12:29
Got it everything is working great now. I can't belive I missed that.
