Dram in 3845 router
Nov 15th, 2009
I have some 3845 routers with 25MB Dram,time has come to upgrade to 512MB
is there antway to determine the existing Dram is 1 x 256MB or 2 X 128MB
obviously if it is 1 x 256MB then I only need to get another 256MB to bring it up to 512MB, but if it is 2x 128MB then would have to get a 512MB twice the cost!
These routers are in production so want minimum downtime,so is there a command that will tell you where the memory is located slot0/slot1 on the main CPU board??
Leo Laohoo Sun, 11/15/2009 - 17:56
I believe the 3800 has only ONE DRAM slot. You can always e-bay your excess stock.
Leo Laohoo Mon, 11/16/2009 - 13:52
Cisco never made a router with more than one DRAM slot. It used to be two Flash slots until the 2690/3700 when they started using Type 2 CF.
