OSPF between sites
Nov 15th, 2009
Hello
I have 3 sites and i ant to interconnect them with OSPF. IOS feature set allows it. Pls look at the attachement.
There are Cisco 3750 switches stacks on each site. The problem is site 1 has two stacks connected via trunk line. I need to keep this trunk working and implement optimal routing.
What is the correct way to start OSPF routing between the stacks on Site 1?
Will it be correct if I create new vlan on Stack 1 and 2 only for ospf connectivity, and declare all other vlans passive-interfaces?
Or is it better to make routed link between stacks (and keep existing trunk too) and run OSPF over this link?
Overall Rating: 5 (3 ratings)
CriscoSystems Sun, 11/15/2009 - 21:37
  • Bronze, 100 points or more
To give you the best answer, it would help to know how Layer 3 routing is currently set up. Do you have a router-on-a-stick setup on either one of the switches?
Is there currently Layer 3 routing between the sites (static, or another non-OSPF protocol)? If so, what is the topology?
DPodtikhov Sun, 11/15/2009 - 23:00
Inter vlan routing is done by the 3750 switches themselves, there is no router-on-a-stick setup here.
Site 2 and 3 are new ones, in fact, there is only one link at the moment - the link between site 1 and 2. Other links will be ready soon.
Routing between this sites is static. Switches at sites 1 and 2 are connected by L3 routed port (not an SVI).
Giuseppe Larosa Sun, 11/15/2009 - 22:48
  • Hall of Fame,
    Founding Member
Hello Dmitry,
it is just enough to deploy OSPF using an SVI interface:
let's suppose new vlan 333 is for routing between the two stacks.
you create the vlan at layer 2
vlan 333
name ospf-backbone
you add the vlan to the list of permitted vlan on trunk between the two stacks
int type x/y
switchport trunk allowed vlan add 333
you create the SVI for vlan 333
int vlan 333
ip address 10.33.33.1 255.255.255.252
! very important
no shut
in ospf you add a network statement for IP subnet of vlan 333
router ospf 10
network 10.33.33.0 0.0.0.3 area 0
this allows you to keep your L2 trunk and to have a path where OSPF is running on vlan 333.
We do so in several campuses
note:
if you have a port-channel between the two stacks make changes to the list of vlans only on the logical interface port-channel they will be automatically reported to member links.
trying to change the vlan list on a member link can cause serious troubles like bridging loops even on powerful standalone C6500 devices.
Hope to help
Giuseppe
DPodtikhov Mon, 11/16/2009 - 00:41
Thank you for your reply.
I suppose I will additionally have to declare all the vlans, except OSPF backbone vlan, passive-interfaces. Otherwise OSPF will form neighbour relationships on each vlan across the stack.
So the setup will look like this:
Stacks on site 1 use new SVI interface to form an OSPF adjacency.
Sites 2 and 3 are connected to Site 1 switches via the routed ports.
Giuseppe Larosa Mon, 11/16/2009 - 09:44
  • Hall of Fame,
    Founding Member
Hello Dmitry,
yes that is correct
recommended or you will join the campuses
Hope to help
Giuseppe
Joseph W. Doherty Mon, 11/16/2009 - 04:25
"What is the correct way to start OSPF routing between the stacks on Site 1? "
Normally, insure the one or more subnets that exist on the trunk are covered by an OSPF network statement. (NB: in your 1st follow up post you mention "Routing between this sites is static." but your using OSPF?)
"Will it be correct if I create new vlan on Stack 1 and 2 only for ospf connectivity, and declare all other vlans passive-interfaces?
Or is it better to make routed link between stacks (and keep existing trunk too) and run OSPF over this link? "
Either would be better for faster OSPF convergence if the connection is lost between the two Site 1 stacks. Both also avoid possible issues with multiple paths when max exceeds max supported by OSPF. Both also help preclude rogue OSPF neighbors. Of the two, I would lean toward using a dedicated VLAN on the trunk. Another option would be to use one or a couple of existing VLANs configured active and others configured passive.
PS:
BTW, ". . . implement optimal routing." also would need to consider bandwidths between L3 devices and typical traffic patterns between them.
