j.huizinga Sun, 11/22/2009 - 23:34
  • Silver, 250 points or more
OK,
Should be implemented though!!!
This is critical!
Bye,
Jan
Adrian Saavedra Mon, 11/23/2009 - 07:09
  • Gold, 750 points or more
Although there's no CLI command for that, as Java said, I think it could be workaround by researching performance counters, alerts, traces and audit logs from the RTMT to determine the cause of a callmanager restarted.
Maybe Java can confirm whether this is feasible.
Hope it helps,
- Adrián.
j.huizinga Mon, 11/23/2009 - 07:25
Good thinking, I shall also have a look at this.
Jan
