PBR clarification
Nov 16th, 2009
Dear friends,
Just wanted a confirmation on the working of PBR
1. set ip default next-hop with multiple ip addresses
If the interface connected to the ip address (mentioned in the set ip default next-hop command) is down, will it automatically stop forwarding to the first ip address and route to the second.
If is connected to Tunnel0 interface and tunnel0 has gone down, will it stop forwarding to Tunnel 0 and just only forward to
2. Will set ip default next-hop override default route in the routing table?
Note: Both the above clarifications are for 6500 running SXI2a code if that might matter.
Thanks and Regards
Mohamed Sobair Mon, 11/16/2009 - 02:43
1- Yes.
2- Yes, but this is conditional command, its executed Only IF matching route is exist on the routing table.
