CUPS 7.0.4 - Outlook Gateway
Nov 16th, 2009
Hi - We are configuring CUPS 7.0.4 Outlook Gateway, however, our initial config had the incorrect certificate cn, we are now trying to use the new certificate which we have uploaded but I cannot see an option in the gateway config to use a different certificate? I have tried deleting the current gateway but when re-entering the details it seems to remember the previous config and certificate details. Has anyone managed to do this before?
I will try restarting the presence engine after deleting the gateway out of hours tonight, but any help appreciated.
thks
htluo Mon, 11/16/2009 - 07:44
  • Red, 2250 points or more
If the new cert is from the same CA, you don't have to anything.
CUPS trust the CA, not the end-entity cert.
Michael
http://htluo.blogspot.com
btmulgrew Mon, 11/16/2009 - 07:51
Thanks Michael - so, even though the OWA server is effectively the CA (self signed) - when the new cert is uploaded to the OWA CUPS should see it? Its just the current "root" certificate on CUPS has a CN of hostname rather than IP, but we have asked the customer to re-run makecert for the OWA IP to be present as the CN value on the new cert (we are not using DNS on CUPS).
Also - well done on a great book!
