Dynamic routing with OSPF
Nov 16th, 2009
Hi experts,
I have four routers: one is 1811 and three 871. I want to configure dynamic routing between them and I choosed OSPF to do that. Because of that routers doesn't have layer 3 FE interfaces but only 8 or 4 port switch interfaces, i am not sure how to do the dynamic routing. I configured Vlan 99 on all of the routers and connected the three 871's to 1811.
To understand me better i attach a picture of the topology!
So with this topology shoul i disable split horizon on int vlan99 at 1811 router??? I think i have to disable it because routing updates from any of the 871 routers will not be redistributed.
Thank you!
Tihomir Yosifov
adamclarkuk_2 Mon, 11/16/2009 - 05:21
  • Silver, 250 points or more
Hi Zenon
Could be wrong but is the 1811 not a fixed chassis, ie, no modules, I did not know you could use them as L2 interfaces but could be wrong, if so then, split horizon will not help you here as that is a Distance Vector protocol feature and you are using OSPF which is a Link State protocol. This sounds more like a configuration issue.
As all the interfaces are in the same VLAN, then I assume you have put them all in the same subnet right?
I also assume you are using the ethernet module in the
Can you ping any of the routers
Have you put the interfaces in to the same area, ie
871 Router 1
interface
192.168.1.x 255.255.255.0
router ospf 1
network 192.168.1.0 0.0.0.0 area 0
871 Router 2
interface
router ospf 1
871 Router 3
interface
router ospf 1
are the neighbour relationships up
show ip ospf neighbour
zenon_electronics Mon, 11/16/2009 - 05:51
Hi Adam,
1811 is a fixed model and there is no module support.
Just to be clear, I have not implemented the ospf routing yet and i am just asking if there will be any problems with this topology. I didn't know that split horizon is a distance vector feature?!
I configured the interfaces that way:
871 Router 1
interface vlan99
ip add 192.168.99.1
interface fa 2
switchport mode access
switchport access vlan 99
871 Router 2
interface vlan99
ip add 192.168.99.2
interface fa 2
871 Router 3
interface vlan99
ip add 192.168.99.3
interface fa 2
1811
interface vlan99
ip add 192.168.99.4
interface fa 2
descr ### to 871 Router1 ###
switchport access vlan99
interface fa 3
descr ### to 871 Router2 ###
interface fa 4
descr ### to 871 Router3 ###
Everything is up and working.
OK so if I use OSPF it suppose to work. What if i use RIP or EIGRP ? Will be problem split horizon then ?
I am asking this because i am still not 100% sure witch routing protocol to use.
Thank you again!
