Services Overhead
Answered Question
Nov 16th, 2009
  • Bronze, 100 points or more
Hi All,
I'm looking for a sizing guide for the ISR's that would indicate what the overhead of L2TPv3 would be.
I'm familar with the router performance guide with the PPS figures, but I have never seen a guide that quotes what the services overhead would be.
My requirements are something that will provide at least 20Mb full duplex of L2TPv3 throughput. There will be no other services running. The two routers will be connected by a 100Mb L3 service.
I'm hoping that the 2811, or maybe even the 2801 might be up to the task.
Any info anyone could provide would be great.
Kevin
Correct Answer by Giuseppe Larosa about 7 years 7 months ago
Hello Kevin,
only performing tests over some hours can tell you if the device fits your needs.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 11/17/2009 - 05:12
  • Hall of Fame,
    Founding Member
Hello Kevin,
Hope to help
Giuseppe
Kevin Brennan Tue, 11/17/2009 - 05:18
Hi Giuseppe,
I was afraid that would be the answer.
I'm working in a small enough company, so we dont have the resources to buy kit just to test it.
Do you know if Cisco VAR's will setup a test lab for customers?
Kevin
