FWSM Bridge Mode
Nov 16th, 2009
Just found out a requirement I did not know about.
I had failover set up for FWSM across two 6500 chassis. Things worked great....except failover between the two chassis took about 4 seconds. I tested and each of five failovers I had a user drop about 3-5 pings before the standby FWSM took over.
So, it looks like I need to take the default gateways off the FWSM and go back to HSRP.
Has anyone had any success with FWSM in bridge mode?
I am going to start scouring the site for links right now but thought I would ask here first.
jan.nielsen Mon, 11/16/2009 - 05:50
Sounds about right, even if you use the lowest hello timers (500mS) it will still spend 3-4 seconds before a failover accours, interface down detection can be optimized by using the autostate feature in the switch, which does not work in VSS setups.
jfraasch Mon, 11/16/2009 - 05:55
I will be running SSO fail over. I have redundant Supes in each of two chassis. I will not be running VSS mode because customer is not comfortable with it.
