Aironet 1250 losing Web Interface
Nov 16th, 2009
Hi;
I configured the bvi interface with a fixed ip address and i am able to ping it and configure it via telnet/ssh. But when i try to configure it via Web Interface it authenticates with my local Usr Credentials and allows me to login, and then if i want to do anything else once i am connected it keeps asking the Usr credentials again and never authenticates. Could someone help me with this ?
Thanks in advance
Rams
jeff.kish Tue, 11/17/2009 - 08:05
Hi Rams,
Can you post your CLI config? That should help us troubleshoot.
Thanks!
Jeff
venkata dandu Mon, 11/23/2009 - 00:30
I didn't configure too much on it. Just created some username and password and a secret password. And when i connected using Web interface using my usrname and psw it is only allowing to level 1. And if i connect using no usrname and my secret  psw it allows me to level 15.
Is there anyway i can tell it to allow to level 15 with my usrname and psw?
Thanks in advance.
