unknow protocols
Nov 16th, 2009
R1
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation PPP, crc 16, loopback not set
Keepalive set (10 sec)
LCP Open
Open: CDPCP, IPCP
Last input 00:00:02, output 00:00:00, output hang never
Last clearing of "show interface" counters 4d18h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
86193 packets input, 10947017 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
3102 input errors, 143 CRC, 923 frame, 0 overrun, 0 ignored, 485 abort
86194 packets output, 11304565 bytes, 0 underruns
0 carrier transitions no alarm present
Timeslot(s) Used:1-24, subrate: 64Kb/s, transmit delay is 0 flags
R2
Encapsulation PPP, LCP Open
Open: IPCP, CDPCP, loopback not set
Last input 00:00:53, output 00:00:05, output hang never
Last clearing of "show interface" counters 4d21h
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/4/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
93445 packets input, 18928426 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
274 input errors, 138 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
93445 packets output, 18562450 bytes, 0 underruns
41 unknown protocol drops
Timeslot(s) Used:1-24, SCC: 1, Transmitter delay is 0 flags
this Point to Point connecetion. I get unknown protocls drops errors. when I ping stress test the T1 I get no errors . can you please explain
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 11/16/2009 - 09:07
Hello Ocporbust,
try to see if this number increments by one every time you do
sh interface type x/y
there is a bug about this that was discussed in the forums some time ago
Hope to help
Giuseppe
