CUBAC - Moving Database Supported???
Nov 16th, 2009
Does anyone know if moving the database from the CUBAC server to a SQL server is supported? My customer doesn't want the MS SQL Express installed on a separate server since they already have a SQL enterprise server.
The CUBAC has the "Database Management" section to configure where the SQL server is sitting. I can't really find anything in the docs saying it isn't supported.
Main reason for this question is that I am receiving the following error message when making configuration changes AFTER customer has already moved the database "Server error. Error Data : FAILURE : 15"
Still need to dive into the logs but wanted to see if anybody knew the Cisco Supported on moving the database.
