WLAN Override
Nov 16th, 2009
I have 2 WiSM in two 6509 with multiple WLAN SSID,aironet 1130 LAP , i use WLAN Override feature , but after a while the APs lose its WLAN Override configuration and i have to login to the WiSM again and check its SSID box again , the Software Version is , can any one help me in this issue?
ehlers.kevin Mon, 11/16/2009 - 09:46
Are the wlan configurations identical on the WiSMs? Do you notice this after an AP moves from one controller to another? I don't have much experience with wlan override, but I know AP groups will have problems if there is a configuration miss-match between the controllers and it moves from one to another.
mohammed.amer Mon, 11/16/2009 - 10:09
the WLAN SSID names are the same but there is mis-match in the profile name does that make a problem ?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
