Virtual Interface Issue PPPOE with Bridge to DSL
Nov 16th, 2009
Our VPN throughput is horrible and it appears the Virtual-Access 2 is only getting 56K of bandwidth while the previous route had 832. see virtual-access 2 below.
Virtual-Access2 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 26/255, rxload 92/255
Encapsulation PPP, LCP Open
Open: IPCP
PPPoE vaccess, cloned from Dialer0
Vaccess status 0x44, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 5 seconds on reset
Interface is bound to Di0 (Encapsulation PPP)
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 1w2d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 189000 bits/sec, 26 packets/sec
5 minute output rate 82000 bits/sec, 19 packets/sec
10796036 packets input, 385980191 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
9025934 packets output, 1819938921 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
Paolo Bevilacqua Mon, 11/16/2009 - 12:32
  • Hall of Fame,
    Founding Member
Which router is that ? Send "show dsl interface".
bob.bartlett Mon, 11/16/2009 - 13:43
it is an 1811 it does not have a DSL interface it ises a bridge to convert from DSL to Ethernet.
Paolo Bevilacqua Mon, 11/16/2009 - 15:20
  • Hall of Fame,
    Founding Member
Likely it is not at fault then, include the configuration if in doubt.
The BW value does not reflect in any way the actual throughout.
In any case you would have best results with a DSL-equipped router.
