Determine the amount of Concurrent TCP users ?
Nov 16th, 2009
From the firewall perspective how can i determine the amount of TCP users that are hitting the firewall.
Is there a command or debug that would allow me to see that.
Overall Rating: 4 (1 ratings)
Collin Clark Mon, 11/16/2009 - 13:02
  • Purple, 4500 points or more
I think the closest you're going to get is with show xlate count.
plumbis Mon, 11/16/2009 - 19:07
  • Silver, 250 points or more
"show conn | i TCP" will give you all TCP conns through the firewall, but this won't give you a count.
You could always slap this into excel to get a count.
Panos Kampanakis Tue, 11/17/2009 - 07:06
  • Cisco Employee,
sh local-host | i TCP flow count
will show you the distinct TCP conns each host has. Adding them up will give you the aggregate.
I hope it helps.
PK
Pravin Phadte Thu, 11/19/2009 - 21:42
Both show connection and show local host would povide you with output for tcp.
But this would be a huge output and diffucult to find a single ip in production network.
A good tool we use is fireplotter which poovides the output for about. Its good one.
Pravin
