871W External Management
Answered Question
Nov 16th, 2009
After much dabbling, I have my Cisco 871W working perfectly with ezvpn to a central ASA5505. Wireless is all good and the tunnel to the main office is reliable. Sorted!!
I have one last thing that I can't figure out. I want to manage the router from the main site through SSH or HTTPS and have tried all sorts on the firewall to get this sorted. The subnet that I will manage from will be 10.1.10.0/23 if that helps...
I've attached the config for reference.
Any pointers would be much appreciated so I can draw a line under the config and ship it out to the customer.
Thanks in advance...
Campbell Thompson
Correct Answer by Paolo Bevilacqua about 7 years 2 months ago
Not sure, I've seen ZBFW only cause problems but never do any good.
You have NAT, nobody can attack you from outside. At least that is my experience in 12 years on installing routers with NAT.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 11/16/2009 - 13:49
I would begin with:
interface FastEthernet4
no zone-member security out-zone
interface Vlan1
no ip tcp adjust-mss 1452
interface BVI1
no zone-member security in-zone
no ip tcp adjust-mss 1412
no ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
You could remove more commands, I've indicated what jumps to the eye.
campbell.thomps... Mon, 11/16/2009 - 14:04
Okay, that works, but ideally, I'd like to make use of the zone based firewall. Which zone would I need to change and how?
Correct Answer
Paolo Bevilacqua Mon, 11/16/2009 - 14:10
campbell.thomps... Mon, 11/16/2009 - 16:16
I really appreciate he help. I agree that I'm more than secure, especially as the 871 is sitting in the client's own firewalled network, so there's limited risk.
I know that Cisco claim that the ZBF is supposed to make things more logical an simpler! I'm not sure that I agree!!!
Thanks again for the help...
Campbell Thompson
http://www.etonbridge.com/
Petar Milanov Wed, 12/09/2009 - 06:12
Hi  Campbell,
To manage your router through SSH or HTTPS, you have to define class-map for this to protocols and to attach it to  policy-map "ccp-permit".  Copy that lines below to your config:
class-map type inspect match-any ssh-https-class
match protocol ssh
match protocol https
class-map type inspect management-class
match class-map ssh-https-class
match access-group 10
access-list 10 permit 10.1.10.0 0.0.0.255
policy-map type inspect ccp-permit
class type inspect management-class
  inspect
Now you should have access to your remote router through ssh ot https
Best Regards,
Tihomir Yosifov
