Lost password router 1700 series
Answered Question
Nov 16th, 2009
Is it possible to recover the password on the cisco router 1700 series without losing its configuration?
Where can I find the procedure to reset the password?
Thank you in advance.
RC.
Overall Rating: 5 (3 ratings)
rafaelcervantes Mon, 11/16/2009 - 14:04
Thanks for the reply.
I am not going to lost the configuration? Am I correct?
Thank you
RC
Jon Marshall Mon, 11/16/2009 - 14:08
RC
No you won't as long as you follow the document. Pay particular attention to step 9 ie.
"Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration."
Jon
