Call Manager Express - Russian FXO ports
Nov 16th, 2009
Hi All,
I have some CME units deployed in Russia.
The connection to the PSTN is via FXO ports.
There is trouble at the end of the call. If ther person on the PSTN end of the call hangs up first, the call does not disconnect properly. Apparenty, the call does time out eventually and hang up after about 3 minutes.
Also, does anyone know where I can get a Russian locale file from?
thanks very much for any help.
alalli
paolo bevilacqua Mon, 11/16/2009 - 14:48
  • Hall of Fame,
    Founding Member
If you do not use IVR, that is not generally a problem. If you need to fix it, search "configuring disconnect supervision".
You need to buy support to download locale files.
