frame relay
Nov 16th, 2009
since I reconfiguring frame realy switch ..
R1 can ping r2 and r3
R2 can ping r1
r3 can ping r1
r2 can not ping r3
r3 can not ping r2
frame-switch#sho frame-relay route
Input Intf Input Dlci Output Intf Output Dlci Status
Serial1/1 122 Serial1/2 221 active
Serial1/1 123 Serial1/3 321 active
Serial1/2 221 Serial1/1 122 active
Serial1/3 321 Serial1/1 123 active
interface Serial1/1
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
clock rate 56000
no frame-relay inverse-arp
frame-relay intf-type dce
frame-relay route 122 interface Serial1/2 221
frame-relay route 123 interface Serial1/3 321
interface Serial1/2
no ip address
clock rate 56000
frame-relay route 221 interface Serial1/1 122
interface Serial1/3
no ip address
clock rate 56000
frame-relay route 321 interface Serial1/1 123
Overall Rating: 4.5 (2 ratings)
Reza Sharifi Mon, 11/16/2009 - 16:03
  • Cisco Designated VIP,
    2017 LAN
Is r1 the hub and r2 and r3 are the spokes? If yes, are you running any dynamic routing protocols? If no, you need a static route from r2 poining to r1 and also static route from r3 pointing to r1.
Reza
cisco steps Mon, 11/16/2009 - 16:27
Reza,
That is correct R1 is Hub r2 and r3 are the spokes.. no dynamic routing protocols ..
R2(config)#ip route 172.12.123.2 255.255.255.0 172.12.123.1
%Inconsistent address and mask
R3(config)#ip route 172.12.123.3 255.255.255.0 172.12.123.1
I tried that and I get and error
Thanks Resa
Reza Sharifi Mon, 11/16/2009 - 18:46
    2017 LAN
correction
You need to point to the network not to the host
cisco steps Tue, 11/17/2009 - 09:09
still not working RESA,
here is my topology, i went to r2 and added
ip route 172.12.123.0 255.255.255.0 172.12.123.1
and on r3
am I doing something wrong . is my frame relay config correct...
Nagendra Kumar ... Thu, 11/19/2009 - 19:56
  • Cisco Employee,
Are you using frame-relay inverse-arp betwen hub and spoke?.
If you use frame relay inverse-arp, try static host entry as below,
R2:
ip route 172.12.123.3 255.255.255.255 172.12.123.1
R3:
ip route 172.12.123.2 255.255.255.255 172.12.123.1
If you have static mapping, configure mapping for spoke pointing to your hub DLCI as below,
R2:
interface
frame-relay map ip 172.12.123.1 broadcast
frame-relay map ip 172.12.123.3
R3:
frame-relay map ip 172.12.123.2
If it doesnt work, Please post the config @ hub and spoke routers as well.
HTH,
Nagendra
