Sizing guest anchor controller
Nov 16th, 2009
40 locations, around 20-30 APs per location, 1 gig back from each site to the main site, minimizing cost. Trying to size the guest anchor controller. Redundancy is not required. As I understand correctly 4402/4404/5508 controller supports up to around 70 EOP tunnels. My limitation is bandwidth. Is it safe to say that if Internet bandwidth is <100Mbps, then 4402 will suffice? Only if Internet bandwidth was above >1Gbps when I'd need to go to 4404 (bandwidth is used twice, so 1Gbps guest traffic would result at approximately 2Gbps throughput)
Roman Rodichev Mon, 11/16/2009 - 16:22
Yes, that's what I was thinking, 4402 is 2gb, and since traffic is anchored the actual throughput is 1gb. What's your Internet connection speed? Thanks!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
