NAC error message
Nov 16th, 2009
Hi All,
I have installed CAA in the PC by browsing NAC untrusted interface. everything worked fine. then I had to change switch IP address. but when I try to login to CAA, it sends old switch IP address. I've uninstalled and reinstalled CAA, the same error. even deleted from registry then reinstall CAA, same error: " OOB Error: switch with 10.1.1.1 (old IP) not found".
any suggestion would be very appreciated.
thanks
Alex
Faisal Sehbai Mon, 11/16/2009 - 17:52
Alex,
The switch would have nothing to do with the agent. Please recheck your IP addresses in the CAM and ensure that SNMP strings are all correct on both the CAM and the switch.
HTH,
Faisal
