AVST CallXpress - CUCM Callmanager Integration: Sample Config Needed
Nov 16th, 2009
Does anyone have an AVST CallXpress voicemail system integrated with Callmanager using the Radvision SCCP (7940) integration? If so, could you post your Callmanager configuration to show how you are getting DID calls to forward to a mailbox?
I have the integration up and running, but call forward to personal greeting is not working for me. Forwarded calls answer with the initial call processor mailbox defined in the answer mode config.
FYI, we have CallXpress version 6.5 and Callmanger 4.3. Thanks!
