Ip Sla Tuning
Nov 16th, 2009
This sla is failing too much and my route fails very often. How can I tune it? I want it even it misses some ping it can miss some more pings to change the route. Say 15 ping is lost change the route. How can I do that ?
ip sla 1
icmp-echo 10.10.10.10
timeout 2000
frequency 3
ip sla schedule 1 life forever start-time now
t-yamashita Tue, 11/17/2009 - 00:34
I think that you can't specify a concrete number of times for the ping.
I suggest you specify a following configuration.
ip sla 1
icmp-echo 10.10.10.10 source-ip x.x.x.x
timeout 2000
frequency 3
track 1 rtr 1
delay down 10
It means it waits another 10sec when ping can't reach to the object.
And I recomend that you specify the "sorce-ip" because keep back a flap owing to ping reachs the object going through backup.
HTH,
Tomoyuki
