POE Error on 4500
Nov 17th, 2009
I'm seeing the following error on a 4500 running 12.2(46)SG
C4K_IOSMODPORTMAN-4-INLINEPOWEROVERWARNING: Module 5 inline power exceeds threshold: status changed to 'Pwr Over'
All the ports on module 5 have "power inline never" applied, in fact the whole switch has POE disabled.
I've attached a txt file with the show power detail output.
Do I have a problem with the module, backplane ??
Thanks in advance.
Giuseppe Larosa Tue, 11/24/2009 - 09:15
  • Hall of Fame,
    Founding Member
Hello Richard,
you shouldn't have hardware related problems and if you are not using POE you are not affected by this.
my wild guess is a SW bug.
Hope to help
Giuseppe
jmacaulay Fri, 01/27/2012 - 09:30
In 12.2(50)SG6 and SG8 I had the same problem.  This is what resolved my problem:
I was able to resolve this issue by using doing the following on the modules that had “Pwr Over”:
     Interface range gig 4/1-48
     Power inline never
     Exit
     Power inline auto
It must recompute inline power.....
