VPN Problem
Nov 17th, 2009
I have setup a Remote VPN connection and its working fine but after establishing the VPN connection i cant access any of the internal server and folders so any help will be appreciated.
mopaul Tue, 11/17/2009 - 05:09
  • Bronze, 100 points or more
Client connects fine but can't access the internal resources behind the ASA.
$$ Assuming clients are terminating on ASA/PIX $$
Try this :-
crypto isakmp nat-t 20
Also , check if you have a NAT 0 statement for the interesting VPN traffic.
M
Durga Prasad M.S Sat, 11/21/2009 - 12:05
hi karamalomari,
you have to enable split tunneling.
also if you are usnig an IOS router as your VPN server then just modify your VPN client config and under transport tick allow local LAN access.
rgds/dp
hope this helps.
