ace 4710 3.2.4 and script
Answered Question
Nov 17th, 2009
Hi all,
i've got a problem with script...
from debug command i receive msg
'(ctx:1) TCLPROBE(hm_tcl_exit_proc): File open failed'
same script works on ACE module....why cannot read script ACE4710?
tnx
Dan
Correct Answer by Gilles Dufour about 7 years 4 months ago
Dan,
you are missing one argument.
Argument number 5 is the regular expression.
arg list = "GET /pls/portal30/ecare.monitoring HTTP/1.0" html 0 172.18.255.172 80
I'm using something like this :
script ace_probe1.tcl "GET / HTTP/1.0" html 1 192.168.20.41 (.*) 80
Give it a try and let me know if it works.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 11/17/2009 - 04:34
  • Cisco Employee,
what is the script you are using ?
Which file do you try to open ?
I see the error is in context id 1, so not the admin context. Did you try it in admin ?
Gilles.
danilodicesare Tue, 11/17/2009 - 04:52
Hi Gilles,
script is attached and works on ACE 6K module. I've copied same script on 4710 and doesn't works (or maybe cannot open file :) ).
Yes i'm using context with ID 1 and i cannot run it from Admin 'cause i've no vlan associated at interfaces.
AceFemaster/FE# dir disk0:
1516 Nov 17 2009 12:31:32 script_ver.tcl
Usage for disk0: filesystem
1104896 bytes total used
10059776 bytes free
11164672 bytes total
AceFemaster/FE# show running-config | include script
Generating configuration....
script file name script_ver.tcl
probe scripted script_ver_foo_80
interval 15
passdetect interval 30
passdetect count 2
script script_ver.tcl "GET /test HTTP/1.0" html 1 1.1.1.1 80 OK
as i said before in normal condition (ace module) script parse file and if see word OK rserver stays alive
tnx and have good day
Dan
Gilles Dufour Tue, 11/17/2009 - 05:56
  • Cisco Employee,
your script works for me in the appliance.
From looking at the code, the error is in the exit function...after the script was executed.
So the problem to write to file is not really an issue.
Could you get a 'show probe detail' to see what is the return status ?
Do you have a sniffer trace showing the response from the server ?
Gilles.
danilodicesare Tue, 11/17/2009 - 06:17
Hi Gilles,
AceFemaster/FE# show probe script_ver_pippo_CS01_80 detail
probe : script_ver
type : SCRIPTED
state : ACTIVE
description :
port : 0 address : 0.0.0.0 addr type : -
interval : 15 pass intvl : 30 pass count : 2
fail count: 5 recv timeout: 10
script filename : script_ver.tcl
------------------ probe results ------------------
associations ip-address port porttype probes failed passed health
real : pippo_CS01[80]
serverfarm: S_pippo_80
1.1.1.1 80 REAL 2 2 0 FAILED
Socket state : RESET
No. Passed states : 0 No. Failed states : 1
No. Probes skipped : 0 Last status code : 30006
No. Out of Sockets : 0 No. Internal error: 0
Last disconnect err : Internal error: Script error
Last probe time : Tue Nov 17 15:07:35 2009
Last fail time : Tue Nov 17 15:07:20 2009
Last active time : Never
in debug i can see a empty string as exit message...
2009 Nov 17 15:09:05.761594 scripted_hm: (ctx:1) TCLWT (scripted_hm_run_probe_msg): Received MTS_RUN_MSG
2009 Nov 17 15:09:05.761656 scripted_hm: (ctx:1)tcl_wt_create_qnode: temp_qnode 0x81137b8 em_msg 0xb689e054
2009 Nov 17 15:09:05.761695 scripted_hm: (ctx:1) TCL_UTIL(hm_tcl_associate_script_buf) - ENTER em_msg = 0xb689e054
2009 Nov 17 15:09:05.761725 scripted_hm: (ctx:1) TCL_UTIL (hm_tcl_associate_script_buf) : Associating script-buf with script_ver.tcl em_msg = 0xb689e054
2009 Nov 17 15:09:05.761755 scripted_hm: (ctx:1) TCL_UTIL(hm_tcl_find_script_buf) - ENTER
2009 Nov 17 15:09:05.761785 scripted_hm: (ctx:1) TCL_UTIL(hm_tcl_find_script_buf) - Found script buf
2009 Nov 17 15:09:05.761814 scripted_hm: (ctx:1)TCL_UTIL(hm_tcl_associate_script_buf) - EXIT
2009 Nov 17 15:09:05.761844 scripted_hm: (ctx:1) TCLWT(tcl_wt_create_qnode): Created qnode 81137b8
2009 Nov 17 15:09:05.761454 scripted_hm: (ctx:1)hm_tcl_run: pid 24428 return_fd 13 ZÕô·h^UØ·(Jî·
2009 Nov 17 15:09:05.762007 scripted_hm: (ctx:1) TCL_UTIL(hm_tcl_set_env_vars): arg list = "GET /pls/portal30/ecare.monitoring HTTP/1.0" html 0 172.18.255.172 80 OK
2009 Nov 17 15:09:05.762041 scripted_hm: (ctx:1) TCL_UTIL(hm_tcl_get_argcount) - ENTER, argv("GET /pls/portal30/ecare.monitoring HTTP/1.0" html 0 172.18.255.172 80 OK)
2009 Nov 17 15:09:05.762090 scripted_hm: (ctx:1)hm_tcl_run: About to run the TCL interpreter
2009 Nov 17 15:09:05.762387 scripted_hm: (ctx:1)Tcl_Itasca_SocketObjCmd: g_num_socket 1
2009 Nov 17 15:09:05.763381 scripted_hm: (ctx:1)tclret 1
2009 Nov 17 15:09:05.763524 scripted_hm: (ctx:1) TCLPROBE(hm_tcl_exit_proc): File open failed
2009 Nov 17 15:09:05.765827 scripted_hm: (ctx:1)TCL-WT(tcl_wt_process_interp_return) - ENTER
2009 Nov 17 15:09:05.765870 scripted_hm: (ctx:1) TCLWT(tcl_wt_process_interp_return): received error from scripted probe!
2009 Nov 17 15:09:05.765903 scripted_hm: (ctx:1) TCLWT(tclwt_send_em_msg): ENTER
2009 Nov 17 15:09:05.765932 scripted_hm: (ctx:1) TCL-WT(tclwt_send_em_msg): exit msg = empty string
2009 Nov 17 15:09:05.764984 scripted_hm: (ctx:1) TCLWT(tclwt_send_em_msg): EXIT without Error
2009 Nov 17 15:09:05.765015 scripted_hm: (ctx:1)TCL-WT(tcl_wt_process_interp_return) - EXIT
for network trace i'm trying to obtain it.
tnx a lot
Dan
Correct Answer
Gilles Dufour Tue, 11/17/2009 - 07:28
  • Cisco Employee,
Dan,
Gilles.
