Strange VPN LAN-TO-LAN Tunnel problem Pix 501 to VPN3005
Nov 17th, 2009
Hi There
We have a strange problem with our L2L connection.
The tunnel is up and I can ping fine though the tunnel, but if I make a simple telnet to a port I get one or two timeouts in my ping every time there is made a connection.
In the VPN consentrator log i can see that Received Packets Dropped increase for every ping timeout I have.
Users on this tunnel often get disconnected in their applications.
Its only though the tunnel we have the problem, if I use a software vpn client to connect to the pix or to the vpn 3005 we dont have the problem.
Anyone who have seen this error before?
Martin
