Hi all, I am not able to activate any service on subscriber and it shows me database failure, when I enter "utils dbreplication runtimestate" on publisher it shows me defining for the subscribers. Can someone help me in both issues?
The content you are looking for has been archived. View related content below.
The 0 operator mailbox is not monitored. By default all vm boxes had a 0 option that would put you into that call handler.I have changed the caller input for all vm boxes to ignore when someone presses 0, however calls are still being sent to it.How ...
Hi,I am reading about Cisco Unity traces and may need a little help with this. The operator mailbox is receiving messages. I want to trace how a call is being routed to this mailbox. I know if a caller into Unity reaches the Opening Greeting and that...
I'm involved in the following setup illustrated below. I am Site 4. I have a SIP trunk via the CUBE to Site 1. Calls route between Site 4 and Site 1 with no problem. Is it possible to use Site 1 CUCM, to route calls from Site 4 to Sites 3 or 2? Is it...
Can I use a RS232/serial to USB converter to control the Cisco CS-DESKPRO with Crestron control? The Cisco Deskpro doesnt come with an RS232/serial port. Controlling to Ethernet is not an option for the project i am working on.
I have a trunk between cucm 6.1.5 and asterisk but when a call is made from cucm to asterisk it disconnects immediately it is picked (call from asterisk to cucm is ok). But it is working with cucm 10.5. I try route call from cucm 6.1.5 to 10.5 then c...
I want to know if certain DN's can forwarded with the called number. When Caller A DN (111) Calls User B DN(222) which forwards to User C DN(333) . I want Caller A to see DN(222) on caller ID instead of Call A's DN which is what we see typically (1...
My expressway version is X12.6.1,Mutual TLS mode is on, both the CA certificate and the server certificate have been imported, then configured an dns zone with TLS verify mode is on ,also have TLS verify subject name, When I initiated the call, I fou...
Hello,Is there any information available about the max Calls per Second the Cisco C8200 & C8300 can handle?
HiGetting Below Error On Expressway-C Although I have configured Guest URL on CMS any idea why getting the status failed ThanksSanjay
I have two BE7K M4 servers, one hosting my publishers for CUCM, CUC, and CER, as well as one CUCM subscriber; and the other hosting subscribers for CUCM, CUC, and CER. All VMs are v11.5. About a month ago, the M4 hosting the subscribers died due to a...
Since the PIMG is EOL, I have a Unity Connection integration question. Is it possible to integrate Unity Connection via SIP to a Nortel CS1000 such that calls to and from voicemail will be delivered and MWI will light on the Nortel phones?I have che...
Hello,i've updated a VG310 from 15.6.3M6 to 15.9.3M9.Since then after every reboot "mgcp fax t38 inhibit" shows up in running-config. I don't want that config parameter.After a "no mgcp fax t38 inhibit" and save to startup-config it's gone but after ...
Hi,I have cucm 11.5.1 version and i would like to add missed call notifications to be sent to emails.Is there any solutions for that?Thanks in advance
We have Cisco Attendant console 14.0.2.2225 and this very annoying issue.Our Receptionist operators are able to see the incoming calls but when they double click to answer, nothing happens, the call continues to ring and eventually dropped. The appli...
Subject | Author | Posted |
04-18-2024 04:56 PM | ||
04-17-2024 01:06 PM | ||
04-11-2024 03:24 PM | ||
04-09-2024 09:23 AM | ||
04-02-2024 03:27 AM |
User | Count |
6 | |
3 | |
3 | |
2 | |
1 |
