Win7 64bit integrated client and Cisco Concentrator
Nov 17th, 2009
Is it possible to connect win7 integrated vpn client to connect to Cisco Concentrator using L2TP, PP2P, ipsec or L2TP over ipsec? Many tanks in advance!
Sfanayei
mopaul Tue, 11/17/2009 - 07:03
Hi ,
To the best of my knowledge you should be able to connect , L2tp , l2tp/ipsec and PPTP client from Win 7 to the Concentrator.
You can use PPTP on the Concentrator , with CHAP, MSCHAPV1 AND VERSION 2 authentication protocols.
In the base group , under General tab,you can select which tunnel protocols are allowed.
Tunneling Protocols
PPTP
L2TP
IPSec
L2TP over IPSec
WebVPN
Hope this helps.
M
mopaul Tue, 11/17/2009 - 08:01
Hi ,
Tunneling Protocols
PPTP
L2TP
IPSec
L2TP over IPSec
WebVPN
Hope this helps.
M
