Cat 6500 recovery question
Answered Question
Nov 17th, 2009
A client of us is having problems with a Cat 6500 switch (a Cat 6500 Supervisor 720 Fabric MSFC3 PFC3A with a s72033-ipservicesk9-mz.122-18.SXF14 IOS). This switch fails to load the IOS image. I've read this document:
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml#catos_ios
And I have some questions about it:
- The document talks about RP ROMmon and SP ROMmon, ¿is this only for an older model with MSCF1 or the MSCF3 has two ROMmon too?
- In the fourth point of the “Supervisor 720 Recovery Procedure”, it talks about RP Mode. ¿What is this mode?
- Will I be able to boot the IOS image from the external compact flash (disk0:)? In another doc I've read:
“SP bootflash/bootdisk is the location from where the system can load and boot a Cisco IOS Software image.(…). The RP bootflash can also be used as a storage location for Cisco IOS Software images, although the system cannot directly load an image from that location.”
Best regards and thanks in advance,
Correct Answer by Vusal Salmanli about 7 years 1 month ago
Hello friend,
In Supervisor Engine 720, after the Cisco IOS Software Release 12.2 SX there are no seperate image files such as a bootloader image and the main IOS image. The Supervisor Engine and the MSFC both run a single bundled Cisco IOS image. You can boot MSFC3 images from any of these:
- bootflash
- sup−disk0 (disk0)
- sup−disk1 (disk1)
- sup−bootflash
You can find detailed answer to your questions and step by step guide for upgrade and recovery processes from these links below:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml
Wish you success!
S.Vusal
Overall Rating: 5 (1 ratings)
Correct Answer
Vusal Salmanli Tue, 11/24/2009 - 08:20
Hello friend,
- bootflash
- sup−disk0 (disk0)
- sup−disk1 (disk1)
- sup−bootflash
Wish you success!
S.Vusal
