Router 1721 not saving Config
Richard Burts Fri, 11/20/2009 - 02:18
The most common reason for a router not saving its config is that its config register has been set to ignore the startup config (typically a setting of 0x2142). The best way to check the setting is through the show version. If the config register is set to 0x2142, then use the config command config-register 0x2102 to fix it.
