trunking problem
Nov 17th, 2009
Hello.
I have to connect two sites(I have connected them and everything works OK).
The problem is that I do not want that broadcasts come from one site to another.
So I have created another vlan on HQ and Remote SWITCH. I have set the port to witch the server is connected to trunk mode allowing the two VLANS.
So when I connet a computer on the remote site I cannot ping that. Any Idea
Giuseppe Larosa Tue, 11/17/2009 - 07:24
  • Hall of Fame,
    Founding Member
hello Enkli,
only a L3 routed link is a firewall for broadcasts
a L2 trunk when working does not block broadcasts.
if 802.1Q trunk verify if native mismatch at the two sides of the link.
this can be a problem.
verify using
sh interface type x/y switchport
check for native vlan line
Hope to help
Giuseppe
LordFlasheart Tue, 11/17/2009 - 07:46
  • Bronze, 100 points or more
Further to Giuseppe's answer you can remove VLANs from trunks by issuing the "switchport trunk allowed vlan remove" command.
hobbe Tue, 11/17/2009 - 08:38
  • Gold, 750 points or more
If you do not want broadcasts to come from site A to site B then you could do one of two things.
Routing, that would set the systems on the different sites in different broadcast domains.
ACL
Acces-control Lists on the outside interface of the switch where you block the inbound broadcast address.
I would go with routing.
The acls will most likely cause problems for you somewhere down the line.
Why do you not want broadcasts to go from A to B ?
Broadcasts are a quite essential part of IP if you are in the same subnet and broadcast zone.
