rvs 4000 dynamic ip and static dns
David Carr Tue, 11/17/2009 - 08:34
  • Silver, 250 points or more
With this router model, there is not the option to use custom dns on the wan if your getting your ip address dynamically.  In order to implement the static dns you would need to implement a static ip address on this router.  However any of the rv042, rv082 and rv016 routers will allow that function.  Hopefully this helps you out Jerbol.
Te-Kai Liu Tue, 11/17/2009 - 09:24
  • Gold, 750 points or more
Static/Custom DNS server can be specified in the Setup>LAN page. If the DHCP Server is enabled, the DHCP clients will get that info and use it for DNS resolution.
