Bug or What
Nov 17th, 2009
greeting all,
i have a trunk connection between 3750 and 4506 and the trunk link is up however data traffic is not going through, i can see that when i ping from 4506 to the 3750 the icmp reach the 3750 but however it is not returning back , is it a BUG?
hobbe Tue, 11/17/2009 - 08:46
  • Gold, 750 points or more
It could be one of many things.
First it could be a routing issue, ie the packet hits the 3750 but the answer is sent somewhere else if there is a routing problem, or not at all if there is no route to the net and there is no default gateway.
ACL
there could be an ACL that does not allow the icmp incomming, or icmp outgoing.
The port could be in span-tree blocking mode
My guess is that it is most likely not a bug but a misconfiguration.
Giuseppe Larosa Fri, 11/20/2009 - 00:04
  • Hall of Fame,
    Founding Member
Hello Seifeddine,
verify the native vlan settings on both sides with
sh interface type x/y switchport
look for native vlan line
look also for the list of vlans permitted on the trunk on both sides.
Hope to help
Giuseppe
Seifeddine-Tlili Fri, 11/20/2009 - 06:36
Hi Giusp,
Thanks for your answer , actually i fixed the prob well i was using Dot1q as a trunk and then when i failed to ping i noticed that the i have an encapsulation failure in my switch from the debug ip packet 120 (120 is an ACL that permit the icmp) so it was for sure a failure in the tagging since Dot1q don`t tag the native vlan however when using this command : vlan dot1q tage native everything got fixed
Thanks for your answer.... hey the NetPro forum looks weird i really prefere the old one
