Using SNMP to Monitor Cisco Nexus 5000
brian.lovelady
I would like to know which specific OIDs to use to monitor the following using SNMP on a Nexus 5000:
- CPU total utilization
- Power Supply status
- Chassis Fan status
The Nexus is quite different from other Cisco devices - any help will be appreciated!
Lucien Avramov
Level 10
Level 10
CPU: oid to use is : 1.3.6.1.4.1.9.9.305.1.1.1 (cseSysCPUUtilization) It's part of the MIB:
CISCO-SYSTEM-EXT-MIB
It will display the value in percent of cpu utilization.
ME-TestBed-A(nxos)# show system resources
Load average:   1 minute: 0.26   5 minutes: 0.41   15 minutes: 0.43
Processes   :   393 total, 1 running
CPU states  :   1.0% user,   4.0% kernel,   95.0% idle
Memory usage:   3634820K total,   1728600K used,   1906220K free
                   81256K buffers, 1037176K cache
dhcp-171-69-89-49:~ lulu-mbp$ snmpwalk -c public -v 2c 172.25.180.5
SNMPv2-SMI::enterprises.9.9.305.1.1.1.0 = Gauge32: 5
As you see, show sys resources shows 95% idle, so the utilization is 5% cpu and that is the value snmp displays.
Power and Fans, it's quite limited
The cisco envmon mib is not supported yet on the 5K it looks like.
That leaves us with the FRU mib : 1.3.6.1.4.1.9.9.117 ftp://ftp.cisco.com/pub/mibs/oid/CISCO-ENTITY-FRU-CONTROL-MIB.oid
The index values will be coming from oid: entPhysicalTable (
1.3.6.1.2.1.47.1.1.1) part of the ENTITY-MIB
1.3.6.1.4.1.9.9.117
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.1.470 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.1.1000470 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.2.470 = STRING: "CentiAmps @ 12V"
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.2.1000470 = STRING: "CentiAmps @
12V"
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.3.470 = INTEGER: 4538
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.3.1000470 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.4.470 = INTEGER: 29
SNMPv2-SMI::enterprises.9.9.117.1.1.1.1.4.1000470 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.1.22 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.1.23 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.1.470 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.1.1000022 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.1.1000470 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.1.3000022 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.22 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.23 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.470 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.1000022 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.1000470 = INTEGER: 4
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.2.3000022 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.22 = INTEGER: -2910
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.23 = INTEGER: -83
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.470 = INTEGER: 29
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.1000022 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.1000470 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.3000022 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.1.3.0 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.1.22 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.1.23 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.1.1000022 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.1.3000022 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.2.22 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.2.23 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.2.1000022 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.2.3000022 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.3.22 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.3.23 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.3.1000022 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.3.3000022 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.4.22 = Timeticks: (1027) 0:00:10.27
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.4.23 = Timeticks: (8520) 0:01:25.20
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.4.1000022 = Timeticks:
(41634711) 4 days, 19:39:07.11
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.4.3000022 = Timeticks:
(41634712) 4 days, 19:39:07.12
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.5.22 = Timeticks: (0) 0:00:00.00
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.5.23 = Timeticks: (0) 0:00:00.00
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.5.1000022 = Timeticks: (0)
0:00:00.00
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.5.3000022 = Timeticks: (0)
0:00:00.00
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.6.22 = ""
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.6.23 = ""
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.6.1000022 = ""
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.6.3000022 = ""
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.8.22 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.8.23 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.8.1000022 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.117.1.2.1.1.8.3000022 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.117.1.3.1.0 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.117.1.4.1.1.1.534 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.4.1.1.1.535 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.4.1.1.1.536 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.4.1.1.1.537 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.10 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.22 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.23 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.149 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.214 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.215 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.278 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.279 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.342 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.343 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.470 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.534 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.535 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.536 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.537 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4950 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4951 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4952 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4953 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4954 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4955 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4956 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4957 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4958 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4959 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4960 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4961 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4962 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4963 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4964 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4965 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4966 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4967 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4968 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.4969 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5206 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5207 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5208 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5209 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5210 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5211 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5212 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.5213 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21590 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21591 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21592 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21593 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21594 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21595 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21596 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.117.1.5.1.1.1.21602 = INTEGER: 2
You can read in :
ftp://ftp.cisco.com/pub/mibs/v1/CISCO-ENTITY-FRU-CONTROL-MIB-V1SMI.my
what the values of the integer means per OID.
Lets take for example (look at file
ftp://ftp.cisco.com/pub/mibs/oid/CISCO-ENTITY-FRU-CONTROL-MIB.oid)
cefcFRUPowerOperStatus : 1.3.6.1.4.1.9.9.117.1.1.2.1.2 for one of the
indexes:
Now we need to find who is 22:
SNMPv2-SMI::mib-2.47.1.1.1.1.7.22 = STRING: "20 port 10GE SFP+/Supervior
in Fixed Module-1"
Now what does mean the INTEGER 2 from :
Lets look at : CISCO-ENTITY-FRU-CONTROL-MIB-V1SMI.my , section
cefcFRUPowerOperStatus, if you search in that file you find :   on(2),
So that measn this supervisor is actually turned on and powered.
yjdabear
This Cacti template has the OID for CPU util, which is nothing unusual (1.3.6.1.4.1.9.9.109.1.1.1.1.8 from CISCO-PROCESS-MIB):
http://forums.cacti.net/about34031.html
That appears to work.
Lucien Avramov
Level 10
Level 10
1.3.6.1.4.1.9.9.117
12V"
0:00:00.00
0:00:00.00
You can read in :
indexes:
in Fixed Module-1"
Thanks for your help!
