Multi VRF and Policy Based Rounting with Multiple Tracking Option
Nov 17th, 2009
Hello
I'm trying to configure a Cisco 2821 (Version 12.4(24)T IPBASE) with Multi-VRF and Policy Based Routing.
It seems that the PBR with Multiple Tracking Option is not supported into this release.
So it's not possible to configure ip sla monitor feature
I have used the Cisco Feature Navigator but I have not found a IOS release with
Multi-VRF Selection Using Policy Based Routing (PBR) AND PBR Support for Multiple Tracking Options
The PBR Multiple Tracking option will be supported in the future on C2821?
bye
Andrea
Giuseppe Larosa Thu, 11/26/2009 - 23:55
Hello Andrea,
I would suggest to open a TAC service request to get a Cisco answer for your request.
However, I would consider a change of feature set like advanced ip services, an ip base feature set is not the most complete one.
This implies to buy the license for the better feature set.
Hope to help
Giuseppe
